Lay up the outside of the stab first,mark with sharp pencil where cross members are located.Position your balsa stick where you just marked off.Mark your balsa stick,then cut to line.Usually the location of the sticks are not critical,so if your off a little bit,don't sweat it.The more you do it,the better you get.jeffo
