RCU Forums - View Single Post - Jeti-duplex-ds-16-2.4-ghz
Old 01-02-2015, 01:36 PM
  #1414
wfield0455
My Feedback: (7)
wfield0455's Avatar
Originally Posted by mmontella
Wayne,
Ok.....got the flap end points set, but still not sure how to adjust mid flap position. Any further suggestions?
Mark
Mark,
Since you have a separate flight mode for each flap position, if you set the flaps to Separate, instead of Glogal in the Flight Mode trim menu, you will be able to "trim" the flaps separately for each flight mode. You should be able to simply select your flight mode that has half flaps and then use the flap trim setting under the Flight Mode Trim menu to increase of deacrease your half flap position.
You can also select Separate instead of Global for the Elevator in that menu and use the Elevator Flight Mode trim to dial in your elevator compensation for each flap setting.
