Originally Posted by
Hossfly
Maybe, "pour..cia 83" you should update your profile and then one can know just what, when, or where your true status really is. OTOH that might not allow you to laugh ! But I will !
For me, when you can remember a .60 Hornet ( maybe a McCoy .65) on ignition, and with no muffler, spitting blue flame on a late evening flight, then I will know that you, "...have been there..." .
Ah, "status" warfare, just like "class warfare", only not.
If all else fails, attack. Got nothing of substance to say, try to elevate your own status while trying to cast doubt on someone else because what, they don't stick build? I could case less, nor should you, as if that has any bearing on a discussion about the AMA. Transparent and desperate, conduct unbecoming as well. But par for the course.
With each post of that nature, it's crystal clear the voters made the right decision. For the second time too!
The AMA is very much needed, as are good people to run it.
It should be an interesting and challenging year for the leadership team.
