The starter is working great
Feature:
1. ONLY suitable for New DLE111 engine, not for old version.
2. Suggest using 3542 brushless motor (about 900-1100KV) with 4mm motor shaft EMP N3542-1000KV 2-4S 504W Brushless $15 EBAY
3. Suggest usingabove 60Abrushless ESC- GET A CHEAP ONE YOU ARE JUST USING IT AS AN ON/OFF SWITCH NOT AS A TRUE SPEED CONTROL
FYI
The starter for the DLE111 or DA100 is not a true EME starter. It is a reversed engineered designed unit which IMHO, I like much better then the EME unit, due to ,you are using a brushless motor not a junk brush motor like EME uses.
I have a EME 55II and two EME 60cc with electric starters and they work great, but with less then 50 starts the brush starter motor let go and I replaced it with a brushless motor and now starts so quick you don't even need to chock it.
I wish EME would come out with a starter for their EME120cc I would get one. I like the EME motor better then the DLE-111 --just me
