RCU Forums - View Single Post - Aluminum Throttle Pivot??? (Savage)
Old 10-11-2003, 11:47 PM
Rex2342
Rex2342's Avatar
Default RE: Aluminum Throttle Pivot??? (Savage)
Your brake rod is not going to work very well like that.When you hit WOT the brakes will be on.If you move the brake slider to the underside of the servo horn you should be able to bend the brake lever to clear the new handle.It shouldn't take much to get it to work right.I don't like the way Integy designed that bar.It looks like it comes out to far and is not only causing problems with the linkage but it looks like you tuned pipe is rubbing on it also.Maybe the HCR ones would be better?I do like those chassis braces!!! You weren't kidding about the anodizing job!.I think i'm gonna have to get me a set of those!
