Originally Posted by
stemo99
Switching, bec switches on and off very quickly to acheive desired voltage output. Linier bec's disapate excess voltage via heat, not efficient. I use only sbec's for my serious models and a few liniers for my knock around foamys.
Thank you Folks. Then can I assume from the above statement that the SBEC is more reliable then the BEC ? To take it a step further; is it safe to believe that ESC's with built in SBEC's can be relied on to provide similar performance and reliability, as using a separate receiver and servo battery supply ?
Thank you kindly.
Ed
