Originally Posted by
jofro
Just curious what you are talking about? "Ailevators"?? Do you mean Elevons or Delta mix? You should set it in the menu as Elevons or Delta mix, not "normal". Does your model have Ailerons? BTW, you should never use EXPO on primary function as Elevator unless you got advanced parkinsons, but in that case you probly shouldn't have Lic. to fly "F-16".
What do you mean about not using expo?
Rod
