Originally Posted by
Jgwright
Bob
I am shortly to skin a wing with Proskin. I have used it once before so know some of the issues, but the potential benefits of its use. I see you used PU glue. What make did you use and what do you estimate its curing time was?
best Regards
John,
I used Gorilla Glue brand (
http://www.gorillatough.com/) - available over here at almost any home improvement store.
It seems to cure fairly quickly (a couple of hours) to the point where its finished foaming and feels dry to the touch. However, I left it overnight on the wing skins with the weights on.
One of my wing panels had somehow warped (probably from hanging around the shop for a year before I got back on the project) and I wanted to be sure it was really cured before I took the weight off least the warp come back. An overnight cure with the weights and the panel is dead straight and stiff as a board...
Bob
