but nothing repeat nothing will cure your (and everyone elses) problem unless the lenth of the horn (from the control surface center, ie hinge point to the clevis hole) is exactly the same lenth as the servo arm (from the center screw to the clevis hole).
May I also add that exit slots on the fuselage sides should also allow unimpeded motion of the wires.
