RCU Forums - View Single Post - EDF thrust variation
Old 02-05-2015 | 05:26 PM
mayoub
thanks for your comments about the BEC. I am not running a BEC . The RX has its own battery supply independent from the ESC's BET which I do not have with these ESC's.As far as learning the throttle positions for each fan separately, I will do that as soon as I receive the tach bought so I can at the same time check the rpm for each fan to see if there are any significant difference. Thanks again
