RCU Forums - View Single Post - Calibrating an ESC with Transmitter.
Old 02-06-2015, 04:45 AM
Rodney
Originally Posted by Ed View Post
Thank you Sir, and no motor needs to be plugged in ?
I've never tried it without the motor being plugged in so can not answer this question. Why would you want to anyway, after all that is what you are using the ESC for and you need to know which way the motor is turning. If it is turning in the wrong direction, you need to interchange any two of the three leads between the ESC and the motor. It is best to have the prop off for initial setup in case it turns on wide open the first time you plug the ESC and battery together.
