RCU Forums - View Single Post - New 1/4 scale build starting
Old 02-07-2015, 07:02 AM
  #39
jerrybern
I did some more work on the Vampire,I got the front part of the fusalage filled in with balsa blocks .The Bottom portion gets filled in after you fit the landing gear in. I also started a plug for the nose that I will make a mold from
to make a fiberglass nose cone that is removable, that way you will be able to service the gear and add ballast as far forward as possible.
Till Next Time, Jerry B
ID:	2071125   Click image for larger version
ID:	2071126   Click image for larger version
ID:	2071129   Click image for larger version
