You can just use a matching two pole plug from any other application. Unless you plug the battery directly onto the board? I am not using Spektrum so I am not sure how it works on that radio.. I did have a radio that the battery plugged into two pins on the board . I soldered wires and a new set of mini deans plugs into that one.
