Originally Posted by
av8tor1977
[ATTACH]2073201[/IMG] I come up with approximately 170 square inches of wing area. That's a good bit for a .049 size ship.... AV8TOR
For a mild reedie, yes, unless built light. This is about the size of the 1/2-A creations by I believe Dick Sarpolus for a Tee Dee / Medallion .049 engine or Norvel .049 / .061.
http://www.outerzone.co.uk/plan_details.asp?ID=2354
It should work for the OS 10R/C. Selecting a prop between 7x3, 7x4, 7x5 will determine flight speed on I'd say on a minimum of 42' lines. It will be quick. Since it is quick building, you could build it, test it. Then if not quite what you were looking for, seek really what will work for you, based on what you learned.
