Originally Posted by
Alex70
Hi hpergm, have you done any tests with supplied pressure nipple of Keleo ring connected to fuel tank vent? How does the engine runs better? ¿Pressurized tank or without pressurizing? any difference in rpm or throttle response?
Holla Alex. No, I have not used the pressure fitting - I am very reluctant due to the safety issues this involves.
A pressurised gasoline tank full of vapor in contact with hot exhaust gasses?
Can you imagine igniting the fuel tank in the plane?
I prefer to test it like it is and see. Worse comes to worse, I will find some other way to pressurise the tank (e.g. a second Robart air tank with a regulator).
