Ok let's get started with the re enforcement to the under carriage under side ply wood.
I first added two triangle balsa wood on both side in the inside of the fuselage with wood glue.
I went and turned the model over to the under side and cut out the covering material,i have to add i thought it states in the web site
from Glens Models that it's pro film or so i thought, well this on pro film or even oracover this is a cheap copy no where near pro film.
