RCU Forums - View Single Post - Dave Patrick Edge 540T - Problem with elevator setup
Old 10-13-2003 | 04:48 PM
jrf
My Feedback: (551)
Default RE: Dave Patrick Edge 540T - Problem with elevator setup
Erick:
Putting the servo on it's side so that the arm is vertical in the center of the fuselage will solve the problem you mentioned.
Bla Bla:
The set up you discribe is only required if the pushrods are rigid. (Otherwise known as a push/pull system.) In a pull/pull system the cable opposite the pulling cable is expected to go slack.
Jim
