Originally Posted by
Nev01
This is how I was going to plumb the retracts, but, when I discovered one of the 4 way connectors was damaged I had to have a re-think, now I'm left wondering what is the best way to plumb using just one 4 way connector. Before I start cutting tubing I would be interested to see how you've done yours.
Nev.
My 4 way valve is at the exit of the 2 air tanks/fill/to valves from there all 3 way valves....the way you have done it is very good if you have limited radio programming available.... but with programming in my radio the brake valve get no air when the gear is up.
