Here is what I use with the Jeti Spin, should be similar I would guess. I still adjust the endpoints on the 18 to get it exactly right, but it will get you close.
Temp Protection - 100C
Brake - Manual
Dead time - 0s
Initial - 30%
End - 46%
Brake Speed - 0.5s
Operation - Normal
Timing - 24 degrees
Frequency - 8 khz
Acceleration - 0.5s
Accumulator Type - Li-Ion/Pol/Fe
# of cells - 4
Cut off - 2.8v
Off voltage set - 11.98
Cut off - Slow down
Initial Point - Fix
Fix initial point - 1.1ms
End Point - 1.9ms
Auto Inc End Point - Off
Throttle Curve - Linear
Rotation - Left
Start up power - Auto
Setting thr. RC - Off
