In this test I wanted to check ESC setup ”Fixed-Endpoints” before I test 12S in this EDF setup.
During the test the motor had stopped when I reduced the RPM and then it didn’t work.
An electro motor specialist saw the motor and said ”The motor has wire cut off ”.
WELLPOWER SE 10S 5000mAh 30C
CHANGESUN Ø 120mm 4 blades
CASLE PHOENIX EDGE HV 120
I used in this test:
-motor timing : low
-pwm rate : 8kHz
-power out : 73,7%
-static thrust : 25N
