If it is ABC, you won't have to worry about grinding the port..I have to use a cut-off wheel to get thru the chrome so a tungsten cutter will ever start to remove any brass.
If it is not ABC, I wouldn't grind on it, any way.
ChuckN and I hashed over a few points here:
http://www.flightlines.com/forum/For...ML/000364.html
