Originally Posted by
erh7771
You have to have an intake lip for the fans, without an intake lip tip of the fan rotor (fan blades) don't "bite" and you loose static thrust and efflux
Contact airsally on RCG... or get a 120mm intake lip from effluxrc.com and get good static thrust \ amp and efflux numbers
Thanks for the info, I will see it.
I guess you are right. The motor KV is too high at the max. 100% RPM in HAOYE EDF. At the max. RPM the ampere was higher than allowed and the motor was too hot, therefore I chose lower RPM where the motor is warm but not too hot during the test and where the fan works well.
I am only getting to know this category.
