New Products from Tamiya now at Banzai Hobby !!!
TB EVO.6 Chassis Kit - TB EVO 6 Black Version
The TB Evolution line-up of shaft drive 4WD racing machines began its lineage in the year 2000. Since that time the machines released in subsequent years have evolved. The new TB Evo 6 continues the tradition of evolution by introducing new design elements and proven parts from many of Tamiya's other 4WD touring car platforms.
The TB EVO 6 shares the same drive train as seen in the TB-04 tub chassis machine, which uses a horizontally positioned motor for optimal torque displacement balance. TRF designers have also incorporated other tweaks to bring club racers the perfect weapon for spec motor club racing. These tweaks include suspension parts from the TRF418 as well as carried over parts from the TB-04.
Aqroshot - DT-03T
In early 2014 Tamiya introduced the new DT-03 off-road chassis. For 2015 Tamiya introduces the DT-03T, which is a TRUCK variant. The platform is intended as an easy-to-get-started model to encourage young drivers to enter the world of R/C. Its intuitive yet tough design allows hassle-free assembly and gives less experienced users the opportunity to get to grips with R/C model composition and construction. The truck variant allows users to tackle bumpy street or parking lot terrain with its taller stance and wide and low profile road hugging equipped tires.
TRF Big Bore Damper - 4pcs
These big-bore dampers are now available for purchase as a set - they were originally included as a part of the high-end TRF419 chassis kit. Big bore dampers have an increased cylinder volume, allowing more oil to be inserted and endowing your chassis with improved grip.
Contains parts for 4 dampers.
Damper cylinder diameter is 0.5mm wider than standard dampers, allowing 10% more oil.
Aluminum parts are blue anodized.
Aluminum Big Bore Damper - M-Chassis (4pcs)
ESC TBLE-03 Brushless - Sensored or Brushed Capable
This is a smaller footprint and lighter model of the Tamiya TBLE-01s electronic speed control (item 45047). As a smaller unit, it cuts down on room required in your chassis, contributing to a lighter model.
Dimensions: 30.4 x 37.2 x 26.5mm
Sensored brushless ESC detects motor rotor positions with precision, enabling more efficient power supply and smoother motor response.
Functions such as reverse cancel, battery cut-off, brake and neutral brake can be set separately.
Comes with a cooling fan to help slow the overheating of the ESC, allowing longer operation times and a wider range of settings.
Sensor cable is included.
Designed for use with Tamiya sensored brushless motors such as Items 54272-5.
Compatible with Ni-Cd, Ni-MH and Tamiya Li-Fe battery packs.
Note: Not suitable for use with rock crawling and twin motor-powered models.
Carbon Damper Stay Rear - TT02
This is a rear carbon damper stay for the TT-02 chassis platform. Carbon fiber parts contribute to the increased rigidity of your RC model.
Carbon fiber damper stay features a number of attachment positions to allow alteration to the shock angle.
Contains small parts for damper attachment, such as collars, screws, ball connector nuts and spacers. Use spacers to adjust damper attachment height and model ground clearance.
Compatible with TT-02, TT-02D, TT-02T and TT-02R chassis.
Note: these stays cannot be used on TT-02 Type-S and TT-02B chassis.
Carbon Damper Stay Front - TT02
This is a front carbon damper stay for the TT-02 chassis platform. Carbon fiber parts contribute to the increased rigidity of your RC model.
Banzai Hobby Team
