Sorry you feel that way. I was not trying to slam you at all it was a legitimate question.
IMO though if the engine is running perfect when you buy the used engine and you use Kingtech oil I don't see anything getting any worse. Now if you have bearing noises or other problems then yes send it in.
Originally Posted by
essyou35
Regardless of the answer I was just blown back by the lack of professionalism to my legitimate question in both of your responses.
Kingtech said it was ok to run certain oils, then changed their minds.
Never was a requirement to send in an engine at 15 -20 hours for DTE lite.
I know its only 300 bucks but I thought it fair to ask is all. I'll probably just send it in anyways to avoid any issues. It just creates a situation where any used turbine purchased probably should be sent in for inspection in case its been running one of the other oils like DTE.
Either way I still like Kingtech engines.
