agree with Jerry on propp, but disagree on spring, servos are strong enough to pull throttle without big current draw, in case the arm vibrates lose or off, the throttle goes to stop and not banans in case of arm failure. Yes there should be a kill option, but case scenario you taxi in the pits, throttle runs away on you, you don't have too much time to respond and kill the ignition ,
jmo
Michael
