RCU Forums - View Single Post - AGM30 Gas engine
Old 04-26-2015, 03:57 AM
  #328
flyinwalenda
flyinwalenda's Avatar
Originally Posted by flyierjon View Post
what servo are you using for the throttle if you leave the spring connected? something with metal gears i assume?
As stated you don't need a metal gear servo, or a fast digital servo unless you are planning to do 3D. An amp meter is a good tool to have to set-up servo linkages so you are not over driving the servo. http://www.horizonhobby.com/ProductD...&storeId=10151
