Originally Posted by
Bob Pastorello
Good discussion, guys, but my initial need is for a fix that doesn't make me remove the cowl, or do any disassembly. I've studied some stuff about adding primer bulbs, but not sure that the stock carbs on DLEs would permit adapting that fix. I wouldn't mind a third 'primer line', if that's what it takes, but I'm at a loss of where to attach it, or what to add to make it work.
I didn't know anything except the very basics of Walbro carbs, so I googled up a "how do they work". Here is one of the many links returned:
http://helifreak.com/showthread.php?t=326599
I don't currently have any problems with my gas carbs, so I didn't read the entire explanation. I did keep it for the future. Maybe there is a clue in the article that lets you know how to open up the pump chamber and get fuel in when you have the problem you have. Good luck. I will be looking for your solution.
sincerely, Richard
