I have used the Dubro pump for about 9 years now for gasoline. This is 1.5 gallon can. The fitings and hardware along with the gasoline pump from Dubro is around 25 bucks. I Also have used this same pump and fittings for about a year now on 5 gallon can that is for pump diesel to use in my turbine jets.
keep in mind that it takes more initial cranks when pumping gasoline or diesel to acheve prime than when pumping glow fuel because of the difference in viscositys.
John
