I'm confused by the pictures.....can you clarify some things?
- It looks like you are using a vanessa?
- with the junk on the elevator stab it looks like you are balancing at the rearmost spot on the wing, right behind the cockpit?
if those are both true:
- that balance point seems very far back, too far back ( currently tail heavy not nose heavy ) ... where does it balance without the stuff on the elevator? I'd expect it someplace about the center spar on the wing.
