Hi MJD,
Thanks for the tips, posting photos will be part of 'the Challenge' for me !
The 'name' of the plane is the hard part ! All the good ones have been used !
Speaking of names...
That 'engine pointing device', I dropped off is called 'theRuntley'.
(A 'Runtley' is an errection so big, you cannot close your eyes, because all the skin is used up...
Your call on the .50 !
Had CG issues with a .32... CF on the spars, doubt you could fold the wing...
There is a wheel collar holding the top and bottom rudders together. The hole might be covered with a sticker.
Should be able to take it apart, file a notch where the set screw hits, and will be good to go.
Cheers,
Dave'crosscheck'Fallowfield
