RCU Forums - View Single Post - C/A-Proof building surface
Old 05-16-2015 | 01:41 PM
Lifer's Avatar
Lifer
C/A is the only glue to use as the surfaces are laser-cut 1/16th balsa. The stabilizers are pressed together and laid on a flat surface then the c/a is applied:
http://www.parkscalemodels.com/shop/item.aspx?itemid=73
As it's flying season, my progress has been slow but I plan to try the plastic sheet method next and will report.
