RCU Forums - View Single Post - C/A-Proof building surface
Old 05-17-2015 | 02:08 AM
Lifer's Avatar
Lifer
I've tried to explain that there are no plans! This is an ultralight, laser cut model that is built on a flat board. You remove the parts from the balsa sheet, assemble the parts and dry fit them together and then apply thin c/a. They have to be laying on a flat surface because they hold the shape they have at the moment glue is applied.
