After setting up a new model with new Hitec HV digitals on all the control surfaces, but an HS-430BH HV on the throttle. I realized that the system I was running had the higher refresh rate (Futba S.Bus with an XPS X10 board). Well, the HS-430BH seems to be perfectly content running at the higher refresh rate. Just for grins, I switch the throttle channel to an HS-325HB, the 325 was very distressed!
Was this newer analog servo designed with the higher refresh rates in mind? FWIW, the HS-430 is my go-to standard sport servo
Regards,
Pete
