Old 06-09-2015, 12:42 AM
340cudaman
340cudaman's Avatar
Default 2 blade to 3 blade
I have the fun cub. I wish to use a 3 blade instead of 2. I like the extra thrust and ground clearance vs a 2 blade. I have a 10-7 3 blade master airscrew, phoenix 50 edge 50a 34v esc, himax brushless outrunner HC3516-1130 and will be using a flightPower li-po 3s 11.1v 25c 24w battery.
Will the 10-7 work with this set-up or will I nedd to use a different prop? I purchased the plane in kit form and is almost completed, so I haven't tested any props yet. Thanks in advance.
