Originally Posted by
Instructor
If the radio being used has the ability to slave a separate servo to the master, reverse the slaved servo. Problem solved....
Larry/Instructor
Thanks for the suggestion Larry. I've tried
mixing the ELEVATOR channel with theAUX1 channel, designating the servo driving L half of the elevator as Master and the servodriving the R half as Slave. This seemsto work fine except that the elevator Trim only trims the Master servo or left half of the elevator; theSlave servo is unaffected by the elevator trim even though the Slave servo tracks the Master servo perfectlywith elevator stick movement. Go figure !! My transmitteris a JR XP8103 with a Spektrum DM9 RF module. Any suggestions to that problem? Thanks
