Help Programming with 12X TX
I recently removed a matchbox which was plugged into CH4 for RUDD / Nose wheel. I now am using CH4 for the nose wheel and mated rudder AUX6 to CH 4. AUX 6 is now INH in Device Select and mated to CH 4. No problem with this, all works fine. What I would like to do is to be able to use the normal rudder trim to adjust the nose wheel without changing the rudder. It sounds like there is a way to INH the rudder (which is my AUX 6) from the rudder trim but I have been unable to figure out how... JR12X, 12 CH Receiver, Bandit Arf. Thx in advance for your thoughts... Bill
