340cudaman
For a given current draw and pich you will obtain the highest thrust from a 2 blade.
The 3 blade will have a smaller diameter but will draw more current to achieve the same thrust and pitch.
My advice would be to use the recommended 2 blade prop first then you will have something to compare the performance of the 3 blade against.
