RCU Forums - View Single Post - How to fix the stripped plug threads on cyl head.
Old 06-12-2015 | 06:31 AM
aspeed's Avatar
aspeed
A Timesert is still the best. A plug can be pressed in and drilled and tapped too, but could loosen up if torqued. The 4 stroke heads can be pricey, and Clarence may be a good idea if you don't do it often. (and yu shouldn't need to)
