XCalibre, I'm ordering a set of blades from Flying balsa and intend to build a set as you did. I noticed you used 2.5 to 3 degree left tilt. Where is your CG? Also noticed it appears you are not using the prop spinner supplied and maybe a prop adapter as the prop looks closer to the motor. Any other thoughts on your setup would be appreciated.
