Wow thanks for that information. Now 2 questions...
1. You said the one you linked is sensorless/uncensored...fwiw what does that fwiw mean?
2. With each motor designation...which is better for all the types...is higher typically better. I.e turns of wire...kv....or 5400....is the bigger number better in all cases power and speed wise?
3. Is it possible to have a good braking system and reverse???
Thank you so much by the way you have taught me a lot of things it would have taken a lot of time to find and read it seems like.
Reason: messed up
