after a little reading that motor might be a little too fast for the m05. The hobbywing at 4000kv would be ok, and if you wanted some more speed it would probably handle a larger pinion down the road. A similar castle setup would be this one
http://www.amazon.com/Castle-Creatio...nder+esc+motor
that motor is a little slower than the original one I posted. either of those should be perfect.
I do not have a ton of tire experience, particularly with the minis/m05.
even though I am suggesting a little 'slower', they both will smoke your old silver can motor
