I will go through the process I use to make a composite fuselage. I'm up to about 10 now, the last 2 were 40% IMAC so this one is relatively small
I dimension the drawing at 100mm stations and transfer it to 6mm MDF. The off cut will be the splitter plate, more on that later.
