Thanks, Ragtop,
Wing (cont)
Ailerons (cont)
Cut the ailerons off the wing and sanded the LE of the ailerons and TE of the wing.
Glued 1/8" thick balsa sheet to the LE of the ailerons and TE of the wing.
Flaps (cont)
LE of the flap ribs rounded in prep for sheeting.
Water added to the outside surface of the 3/32" thick balsa sheet and glued to the LE of the flaps.
