Thanks Reuben...
Workshop is slowly filled with parts. Few days ago wing and other parts come back...
I start work on parts immediately. First I glued balsa sheets for elevators...
Than I want to put elevator ribs on trailing edge, but unfortunately some ribs are missing.
Some other small parts are missing also, so I need to send file to my friend Dragan, to cut all parts on laser cut machine.
In meantime I send to Dragan file with all fuselage ribs for 1/5 scale Galeb and another file with ribs for three piece wing for bigger 1/4 scale G2.
As you know, projects like this depend from many peoples, so here is same situation. Many participants in this story you know from earlier.
One of them is Misha, who print plans in his firm. Yesterday plans for wing and elevator of the bigger G2 arrived...
Sorry for "nude pictures", but here is almost 40 degrees Celsius, so we use all to cool off...
On 1/4 scale plan I put 1/5 scale plan. Check a difference in size...
Maybe this angle will be better...
Because wing on 1/4 scale model will be from three piece, my friend Sava made glass tube for aluminum wing joiner...
Glass tube will be glue in center panel section...
A little close-up...
From carpenter who made before tools for tip tank for vacuum machine, I order it again. This time tool is for 1/4 scale jet...
He made tool for front light, but shape is not good, so that will be done one more time.
I bought back retracts and wheels from my friend. This Behotec set was install here before...
And for the end, from Frank Tiano I got box of ZAP glues... Thanks...
He put in box "Z-ends" also...
That's all for today...
Regards from Senta, Serbia
Mirce
