Originally Posted by
hsukaria
I compared the standard length HSNs for the gas and glow. The gas version is more gradual. However, I received it from the previous owner with a chewed up o-ring. That is why I used the LONG HSN instead, which is very gradual and some have said it makes it easier to tune. When I receive the new O-ring from NV Engines, I will switch back to the short gas HSN.
Cranked my GX-40 up in the Escapade yesterday. Won't run right. When the engine is stopped there are air bubbles traveling from the carb into the fuel line at the inlet nipple (the nipple is pointed slightly upwards). Got to figure the O-ring on the HS needle is leaking.
Ordered parts today.
I was going to order a nitro HS needle but they're out of stock!
No maiden this weekend!!!
CR
