Originally Posted by
hsukaria
I also found out that the needle jet assembly was loose. I tightened it against the carb body. I don't know why it worked itself loose, along with the needle valve o-ring being chewed up. But you might want to check the carb needle jet assembly and make \sure it is tightly secured.
Yes, I found that I could loosen the jet tube a bit so as to rotate the fuel inlet nipple to the most convenient placement. That nipple fitting is sort of soft on the surface, has no gasket, seals OK when the tube is tightened up. NV offers a brass fitting also. I suppose it uses gaskets or some such.
I ran the engine yesterday morning after installing the new O-rings. It ran fine once I got the LSN set right.
CR
