RCU Forums - View Single Post - 'Staying Logged in' Problem -- SEE POST #22 FIRST
Old 08-17-2015 | 04:13 PM
IBobi's Avatar
IBobi
Exclamation Possible resolutions, and knowledge drop
A few things:
First, the screen shot that was pasted in here by Blancr -- the link is *not* where you pointed to, where it says:
Are you having login problems? Read me!
The link is *underneath* that where it says:
Some members have had trouble logging in or staying logged in. Please try logging in after clicking here
Click where it says "clicking here".
This will clear your login session cookies.
A link to that page is here:
http://www.rcuniverse.com/forum/cookies.php
Second, this should be your login routine:
1. Go to https://www.rcuniverse.com/login-for...emberadmin.cfm and enter your Username and Password, and click "Log In"
2. Do not forget to have cookies ENABLED on your browser; otherwise *you will not stay logged in*.
3. After you click Log In, you will be taken to a short interstitial screen thanking you for logging in. Then it will take you to your Member Account Info Page, showing your member profile.
4. When you click FORUMS in the header menu, you will be logged in.
It is important to know that RCU is actually two sites linked together: the forums (which runs on VBulletin), and the Marketplace/home page/everything else (which runs on Windows). There is a single sign-on that logs you into both. But there may be some instances where you will *appear* to be logged in but you won't really be logged into both sides of the site. If you follow the above steps, you ought not to have a problem.
IF YOU STILL HAVE ISSUES AFTER FOLLOWING THE ABOVE,
Please post the following:
1. Your device type (desktop/laptop, windows phone, android phone, iPad)
2. Your browser type and version
3. You O/S
This way, if there is an issue affecting users of one type of device or browser, it helps us narrow down the problem.
Thank you,
Paul
