Also, just an FYI. I am sitting here assembling my Carbon Z T-28 and I have found on mine I had to notch the flap servo cover on the right wing if looking at the plane from sitting inside the cockpit. Same notch as above, just the right wing. Also, the motor install addendum has an error. It says to install the motor using 4 screws from Bag B. That is incorrect. Use the screws/bolts from Bag C as stated in the manual. Also, has anyone had cowl clearance issues? I am finding my cowl doesn't want to go on very easy and seems to be rubbing in the dummy radial somewhere so I might has to make some extra clearance there as well.
Jason
