RCU Forums - View Single Post - FB 1/7th F15 scale build
Thread
09-30-2015, 02:29 AM
30
mick15
1 Post
I had no end of trouble with the main gear on this model,for the designers to expect the tracking to be controlled by that lever fixedto a silly little square was ridiculous. They did introduce a mod in the formof a bar fixed to the side frame but that too was ridiculous (don’t know ifyours has this little modification)?
My solution was to introduce a tailored block bolted to thecross beam for the leg to fit into, the centre bolt fixes the block to the beamwhilst the two outer bolts are for tracking adjustment. I also converted thegear and doors to hydraulic to get over the problem of the gear and doorsrefusing to work properly in the considerable air stream after take off.
https://youtu.be/dIfvzfLCNQQ?list=FL...DJcUNuf7YKFO-A
Reply
Like
mick15
View Public Profile
Send a private message to mick15
Find More Posts by mick15
View iTrader Profile
