RCU Forums - View Single Post - Das Not Ugly build
Old 10-03-2015, 10:27 AM
gvc
I'm using an Atlas outrunner 2308/14, but don't remember exactly what those numbers mean. I think the motor diameter is 23 mm. With an APC 7x4 it is likely under propped but should be fine with the 3 cell 460 mAmp lipo. The ESC is an old Jeti Eco 12 amp unit. I have the same set up on another plane (photo attached) and it really scoots. Rudder/nose gear and elevator will be moved by JR 241 servos and the ailerons will use a Futaba S3114.
